Making a PCG_FX701 quicker
JohnGreen
I have a PCG-FX701 with a athelon 1400 processor. its ok, though a little slow at times, what could i do about the RAM to improve the overall performance, and if so what type of memory do i require. Can i get chip upgrades for the processor? And can anything be done about putting a bigger hard drive in it? Is there and graphixs cards avalible for running games? Id be very gratefull for any help in this matter.
John
1 REPLY 1
kee-lo_
Hi John
You would have to get some RAM (512MB if possible) with the best performance the motherboard will allow.
Go for a new 7200RPM disk, makes a difference to 4200.
As for the CPU, I don't think you can go a lot higher than 1500, check the FSB is the same and it will work in a Socket A motherboard.
