If i need to register it again then how because i tried doing it but i couldnt because the drop-down list during registering does not shows the model?
Message was edited by: aqdash
Hi aqdash,
Vaios are held on a separate database - so you will not see your Vaio on the 'My Sony' product list.
It is probably registered correctly. The reason you cannot find the model in the drop-down box is because you must register on the Vaio website.
Try going to the Vaio after-sales service website and enter your Vaio's Serial Number under Login Option 1 and see if it is recognised there : -
http://support.vaio.sony.eu/computing/vaio/index.aspx?m=0&l=en_GB
You can click on 'Register' there and enter your Names and Serial Number. If the Vaio is already Registered to you, all your registration details will be displayed. Make sure the names are as originally used or it will not find your details.
