How do I restore to factory settings for VGN AW11S/B vista 32
SOLVED
iceman630
I have erased all the data off my Vaio VGN AW11S/B vista 32bit laptop in error and although i thought i had done recvery discs, these are not recognised and all i get is operating system not found.
Is there any way i can get discs to re-install it to factory settings as when I purchsed it?
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
HI Roy,
Assuming you have not deleted the recovery partition on the hard drive you will have the option to recover to factory settings by pressing and holding F10 at boot – this should launch the recovery utility.
Otherwise you can order a set of recovery disks from Support by calling the OOW number. From the UK the number is 0905 0310006 (£0.35/min). The cost of recovery disks is approx. £50.
Rich
Go n-éirí an bóthar leat
1 REPLY 1
rich912
Contributor
HI Roy,
Rich
