hello I have a strange noise coming from my new vio VGN C1Z. I'ts a high-pitched.The noise stop when the power cable is input.
It'look like's a hard drive problem maby can some one help me ?
Hi trebiv,
My suspicion is that you are experiencing a common problem that a number of members have reported, and that is the screen produces a high pitched noise when set to anything other than maximum brightness.
On battery power the screen will default to a lower brightness level than maximum, but running on mains power the level will be maximum brightness.
You could check out this theory by using power management to set the screen to maximum brightness (or just use the FN + F5 keys) while running on batteries.
If my theory is correct I suggest you contact Sony support for an explanation/solution.
Thanks alot, but no change with your solution...
What els?
I have escalated this problem to Vaio-Link as I have seen at least four posts on the subject from new C-Series users.
Defo puts me off the green VAIO Shame on you Sony
Hmm, I also have a C1Z/B but havent experienced this problem.
Will keep an ear out for it
And have you got a problem with audio apliances ?
Hi guys,
did you find out anything more? I have the same noise, the strange thing is that it disapears when I connect usb memory (note, a normal mouse will not have any effect on this). I would be a pity to always have to carry around a usb memory just to stop that noise...
thanks
Hi guys,
thanks
