High pitch noise problem in E series
jimbowong
Hello,
I'm wondering if anyone can help. I have recently purchased a customised E series laptop and am loving it except for one problem, but a large very annoying problem. It is the 15" version and customised to the highest of specs but even when the laptop is on with no applications open there is a high pitch noise coming from the laptop. I have no idea what it is and turning the volume on or plugging in earphones does not change a thing. I would be very very grateful if anyone could help!
Thanks!!
9 REPLIES 9
xDreamer_89x
I've just bought a S series and i think i have the same problem as you, every time i load something etc i get a horrible high pitched sqeak which annoys the heck out out me! but the difference is when i turn the speaker off mine goes away. i checked the sound setting and no sound is turned on to go off like that.
also when i made a video call i cant hear the other person talking, all i get is the horrible buzzing!
So if anyone can help me also on this matter i'll be very greatful, thanks.
Thalamus.
Champion
Hi jimbowong ,
welcome to Club VAIO.. :slight_smile:
If the noise concerns you then I suggest you open a case with vaio support, to find contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Then Log-in and select Get In Touch
rafal212
Hi there
I am experiencing the same problem with high pitch noise coming out of bottom left hand corner of my Sony E series laptop. Various reports which I found on the Internet mention the problem with CPU. I have already had my motherboard replaced under the warannty because of that noise but that did not fix the problem. Guys at the Sony shop said that they defenitely can hear that and requestes replacement of the motherboard.
I have just opened new ticket with Sony Vaio support and I am going to return my laptop to the shop for the second time, If the problem persists I will require refund of my money. I am disappointed a lot because of that because other than that so annoying problem, this laptops works very well.
cupnoodle11
Hi
I am also experiencing this problem too which is very irrating. It's louder when I unplug the charger from the laptop. Everything else is fine.
Can you let me know how it goes so that it will give me an idea of how to tackle this problem.
Thanks
rafal212
When I sent my Sony Vaio back to the shop where I bought it from they sent it to the Service and got the motherboard replaced. That did not fix anything and the noise is still there and I start to regret that I bought this laptop. Staff from the Sony shop called me to say that engineer from Service Desk told them that laptops from this Series are prone to this problem but unfortunatelly the noise is still acceptable. Well, nobody actually ever measured the strength of the noise and how annoying this is. I was told that I would be somehow compensated because of that problem but nobody called me since the few days so I think that they want to forget about this.
I am totaly fed up with this and think of selling this machine.
goawaynoise
I have one of these horrible laptops!!  I bought it online and sent it back after 10 days.  I told them the processor was making a high pitch noise and they needed to replace the processor and the cheap parts around it that kick in when the processor goes into power save......they told me the noise level was acceptable and when I said it was not acceptable and pushed back they then came back and said they did a bios update (first thing I did when the noise started) and that it was fixed.  I said I did a bios update and that the bios can’t fix this issue but send it back and I will just send it back to you if the issue is still there.  I got my laptop back and it was OK for a couple of days then BOOM, that horrid noise again!!  I called Sony and told them that I had the same issue.  They collected my laptop and then called me to say that I could turn off C3/C6 support so the processor does not go into power save.  I said I don’t want to do that as it will reduce the already rubbish 2 hour battery life and my laptop will heat up more causing the fan to come on more and possibly burning something out.  What I want you, Sony, to do is replace my processor with one that does not squeal.  They then then came back and said there is nothing wrong with my laptop after all…..even though an hour ago they acknowledged there was an issue with the processor making a horrible high pitched noise!!  I said the customer service girl can you look at this as if this was your laptop……would you be happy to have paid £800 for a Sony laptop for it to make this horrid noise that you just cant hide from….it is all you hear and makes me not want to use my laptop I paid £800 for!!  She agreed with me and pushed this back to the tech’s.  A day or 2 later I got a call from Sony to say that my laptop is normal, nothing wrong with it.  I pushed back saying the same things over and over…..this guy agreed with me and pushed this back to the tech’s.  2 days later I got another call from Sony to tell me the same story.  My laptop is normal and the tech’s will not fix it.  I pushed back again, again, again, again…..they had my laptop for over a month, longer than I had it for and still they refused to fix it.  You know I bought a Sony as I wanted a Sony and I expected good quality as I am paying double what I would pay for a dell or an HP and for Sony to give me this run around is something else!!  Any ho.  I told Sony that they can keep their laptop and I want my money back which they said they could not do as it was out of the 14 days….I alluded them to the fact that I have had the same issue since day 1 and you had my laptop from day 10 so I am still in the 14 days…..and if they will not give me my money back then I will get my credit card company to refund me the money, (which they are happy to do as I called them and told them the story) and then they will chase Sony for the money.  So after that conversation some else called me from Sony and told me to take my laptop back and then as soon as I get it back to call back and my call will be escalated……this is where we are today.  I have just got my laptop back from Sony after they had it for 2 months and it is still making this horrid noise and to make matters worse there is a mark on what looks like the inside of the screen!!  WTF!!  I am calling Sony tomorrow first thing to send this back at best I will get my money back, at worst I will get a new laptop that does not squeal.  This experience has left such a bad taste in my mouth that I will never buy a Sony product again!!  Sony should be ashamed, they are meant to be up there with Apple not lower than…..sorry I can’t insult another brand as they all have to be better that Sony and for a third of the price!!
Message was edited by: goawaynoise
kamw642
Yep, exact same problem with my custom built E series, an intermittent whine/whistling noise that comes from the area above the keys that is present all the time but gets noticably louder when you revert to battery power. Really annoying! I d'n;t think it has anything do with speaker or mic. Could it be the CPU? It seems to respond to CPU usuage - it chops and changes more when you open a big application etc, but always settles into a consistent whine. But with the AC power in it does go quieter - only by a margin and is still audible, so perhaps it's a combination of issues. Nice machine, but flawed. What a pity.
east_eden
Having the same noise by the sounds of it on my F series.  As the fan noise is also an issue, I was wondering if the whine was the fan or the hard drive?  It seems the machine has to work very very when it is not being asked to do very much. Sony have not responded to my request for a refund.
profile.country.da_DK.title
HenrikL
OH Man. My very first laptop, and then this. Have bought laptops 2 wife, kids etc. and never anything like this. A quiet pricy quality product from Sony, and I have 2 put in earplugs when it runs only on battery...lovely.
Wrote the danish support, but nothing usefull from there yet...surprise. I'm gonna do what ever I can 2 warn as many people I can against this.
Sony keep selling this wellknowing its fawlt! This is simply not good enough! PFUUUIIJJJ!!!
