HELP SONY HOTKEYS BRIGHTNESS MANUALY
pocketmon
Hello,
i have a VGN A115M and the Hotkey Fix for Vista don't work.
Can i put the brightness of the monitor manually up?
It's tierd to have set the brightness on level 1. :slight_frown:
Can i change it in reg edit or something?
Another Problem is, if i open Power Options and then Vaio Power Managment, i get a error
Windows Host Process (rundll32) has stopped working.
Problem signature:
Problem Event Name:APPCRASH
Application Name:rundll32.exe
Application Version:6.0.6000.16386
Application Timestamp:4549b0e1
Fault Module Name:SPMPanel.dll
Fault Module Version:2.0.0.12040
Fault Module Timestamp:4574bd99
Exception Code:c0000005
Exception Offset:000090d7
OS Version:6.0.6000.2.0.0.256.1
Locale ID:1031
Additional Information 1:240a
Additional Information 2:00e1584871e7ac67811a52fa9bf6e935
Additional Information 3:7acf
Additional Information 4:0a7eb594dbdbad05a6c4710f78541c64
best regards
1 REPLY 1
profile.country.fr_BE.title
benste
Contributor
You may change the brightness options in your Bios.
