Hard Drive Replacement Question
ColinCampbell
My HD in my PCV-RX305 is reporting imminent failure. Must I replace it with the same model (Maxtor 4D080H4 - 5400 rpm) or can I use any HD with an IDE interface?
3 REPLIES 3
William
You can use any make or size (Gb) of IDE HDD as long as the Bios and Windows supports much larger sizes.
If you have XP with SP2, I think you should be fine.
Have a look on Ebuyer.co.uk amd compare sizes for the best Gb/£. When I purchased a HDD about 12 months ago I went for 160Gb as that was the best size for the £'s.
ColinCampbell
Thanks,
I'll try a cheap 80Gb 7200rpm drive. Will let you know how I get on.
C
kee-lo_
