My FS315Z seems to freeze when I take the power cord out... works fine again when I put it back in (Battery connected)
Anyone know what the problem may be?
Thanks
It sounds like an APM problem! I would check all the settings in Power Management.
Have you had a look to check that the system is not not set to go into standby in a short period when running on battery?
Sorry I can't be more helpful - what have you tried?
Power settings are ok... I have left them the same for months now, and this problem has only started in last couple of days.
Well, still does it, after restoring my C:\ using recovery CD.
