I found an curios issue with my FE11S's keyboard and wonder wether it's just my machine or anyone else here noticed this issue;
I use to type fairly quick, which often results on 3 simultaneous key strokes. This doesn't seem to be a problem, until I press the combination "cad"; cas can be typed without releasing any of the 3 keys, but cad can't be typed until the 'c' key is released.
After some investigation I found this happens with some other combinations... qwe ewq... but not with zxc, for example.
Well, whilst this issue is not so annoying, it causes some typos specially when using spanish language (that often uses sylabs like das, which can't be quickly typed).
This is a bug of my machine or common issue with Vaio keyboards? BIOS/driver issue or hardware based?
Edit: I searched the forum for keyboard issues but none of them talk about this one. I'm sorry if this question was already addressed before.
