My VAIO PCG-K195HP
When my external monitor is on, I have only the wallpaper on my LCD and the FN FN doesn't work.
An idea ?
I gues you have installed W XP SP2?
I had the same after installing SP2 (with another Viao).
Try to:
- update de BIOS
- update video drive
-update hotkey
See also http://www.vaio-link.com/hotnews/XML/showsol/showsol.asp?l=en&sol=Service
No I have XP PRO SP1
Try activating the external monitor directly from control panel - display settings.
Also, do the other hotkeys such as volume/brightness work OK?
