someone know if I can connect a Vaio Entertainment Docking Station on my Vaio VGN A217M like a vaio Model VGN A217S.
I saw a technical specification of both model and it seems like exactlay the same just some little difference from theese models: 217s have more HD (80 vs 100 GB) and this a docking stations.
But I don't know which one is.... (pgra 1?)
Pls help me
Manellik
There is a port replicator available, VGP-PRA1, but it does not have a TV tuner, if that is what you are looking for.
Specs:
4 x USB - Hi-Speed USB - 4 PIN USB Type A
1 x network - RJ-45
1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
1 x display / video - DVI-Digital output - 24 pin digital DVI
1 x display / video - VGA output - 15 pin HD D-Sub (HD-15)
1 x display / video - S-video output - 4 PIN mini-DIN
1 x display / video - composite video output - RCA
2 x audio - line-In - RCA
2 x audio - line-out - RCA
1 x audio - SPDIF output
Have a look
here.
Specs:
1 x network - RJ-45
Have a look
here.
Yes, I know which one you refer to, but I don’t think that it is for sale separately, only as part of the original package for some reason – I am open to correction on this.
I saw on www.sonystyle.com that they call it "AV dock" for VGN A series, and also they say : The AV dock cannot be purchased separately. If you do not select the AV Dock as an option, it will not be available as an accessory"....
but my question is:
If I buy it for a replace part, from a tecnical parts, it will running on my A217M?
Thanks
I suggest that you check what options and accessories were available for your model on purchase.
If this AV dock was an optional extra for the A217M, then I cannot think of any reason why it should not work - if it is a European part that is..
