DVD not working PCG-GRT896SP CR*P Customper service
kev100
I have a PCG-GRT896SP laptop and the DVD drive has stopped working, I know its the DVD thats at fault because I have swapped it in another machine and it had the same problem, and my friends worked fine in my computer,
DVD Model PCGA-RDVGT2 (Pioneer number DVR-K12DVA)
I phoned up Sony support and they would not accept the DVD on its own because they say that they have to have the whole laptop back, which would take 10 days (the unit is only 7 months old)
For me this is impossible as I travel to france and back a couple of times a week and I need my laptop with me at all times, I also have some very expensive business work on the laptop, even with a format the work can be recovered and I cannot allow this to happen.
My question is firstly has anybody else had similar problems with this laptop and the DVD drive.
Secondly does anybody have a solution, apart from buying a new DVD drive, that can allow me to either get the DVD rplaced or repaired.
I cannot believe that sony cannot be more flexible with their support that they will not accept the DVD drive back, (even though the problem has been diagnosed for them) without the rest of the laptop.
Thanks in advance for any help
6 REPLIES 6
kee-lo_
Yeah it's not easy really, they need to do their diagnostics too.
The only thing I can suggest is have it repaired when you have some holiday time.
TygerTyger
Hm....I think this Sony it's a little unfair, god forbid, to say Sony's customer service is cr*p just cos they won't send you a replacement when you ask for it. I mean who's to say you haven't just been using your DVD drive as a drinks tray and would like a new one please because it's a drive fault and it wasn't my fault and it's your fault and ignore the coffee stains. :smileygrin: Not that I'm saying your dishonest, but some might be.
Anyway I might suggest if you are feeling wealthy and really don't want to send it in you could simply try buying a new drive off Sony.
Or alternatively, there are lots of encryption softwares out there, perhaps pricey but you get your moneys worth. Have a look around and if you feel confident your work would be safe if it was encrypted then do that. If it's very sensitive information you should do that anyway in case the laptop is lost or stolen.
OR cheaper painful method, copy all your senstive information elsewhere, and find a program that permanantly deletes files by overwriting them a few times. It may be recoverable by someone with very sophisticated software, but certainly not by the equipment in a Sony tech support lab.
kee-lo_
XP Pro can encrypt files anyway, and zip them up with passwords.
But PGP is the real tool :smileygrin:
kev100
Hi Guys, thanks for the replies,
I told sony that I would gladly send them the dvd drive (as it just slips out from the side of the laptop) first and then wait for the replacement after they had done their own diagnostics on the drive, I even offered to pay the post and cost if the drive was found to be not faulty.
thge main issue with sending my laptop away (apart from all the work on their (which I have backed upI just dont want it getting into the wrong hands as it is it related to a government agency)) I do use it every day and I travel backwards and forward to france twice a week and I really cant do without it for a day, let alone 10 days that sony say they will need it for.
Anyway I have been doing a little more investigation on this drive, and it would seem that there is a ribbon cable on the underside of it that is actually wearing away with the opening and the closing of the drive door, this is rubbing against the metal chassis and I am assuming that this is causing the problem, I managed to move the ribbon a little and the drive started working again, but over the few days that I have been using it the ribbon has returned to it original place and started to rub again.
I dont think that it would be too much hassle for sont to just take the drive that I post to them and look at the problems that I have pointed out, they will know if there is a genuine failt there or whether I am trying to pull a fast one (which I am not, I just want to get the drive repaired or replaced with the minimum fuss and disruption to me, in fact if they did it my way there would be no disruption to me at all and they would have a very happy customer)
anyway I dont think I am going to get this solved by trying to get sony to just take the drive,
does anybody know if sony has local repair agents in the birmingham/west midlands area that can fix this under warrantee or can at least get me another ribbon cable so I can fix it myself.
Thanks for any replies
TygerTyger
Ribbon cables are usually standard, you should be able to buy another one for a few pounds, dabs is as good a place as any, but don't hold me to it. Go to Vaio-Link for a list of support contacts, which includes the Sony UK number which I think you should give a call. I don't see any reason why they shouldn't be flexible, although I still think they may ask for the whole laptop, as a hardware problem can often relate to software, or another piece of hardware. If you can afford it, and Sony don't want to play ball, I'd suggest simply buying a new ribbon cable, and failing that a new drive. Sony will tell you which cables and drives are compatible.
kee-lo_
If it's a government agency don't they have their own technicians that can fix it for you?
