Hi I need help. I cant find vista drivers for a vaio pcg-8112m
Hi jonah007,
The reason you are having problems locating drivers is that you are quoting the number from the underside of the notebook – this is a chassis model number that can be shared by several models.
Have a look on the screen surround – you may find that it is a VGN-AR series. Given the correct product model number we will be able to point you in the direction of available drivers.
Rich
