sorry guys,
i have follow the istruction for have the bottom FN+F* working,
but not good result!!
what s happend,?what a can do now?
it was a sony error by update...i need this working!!
Hi osservatorio,
If you let us have your model number we may be able to help further....
my pc is sony vaio vgn sz1vp
i have already try to reinstall suite utility, but nothing.
the problem is starting fter some update.
help me please!
Can you please confirm that you have carried out the following?
Download the pre-installed utilities for your model from Vaio-Link.
1 Install Sony Utilities DLL (Install folder 1)
2 Install Sony Shared Library for XP (Install folder 2)
3 Install Vaio Event Service (Install folder 5)
Re-boot your computer.
Repeat this procedure up to three times if the function keys do not work immediately.
http://www.vaio-link.com/downloads/info/info.asp?l=it&url=Vaio/Original/SZ1_Utilities.zip&ip=Preinst...
PS: there is original pack utility, i dont know what u mean with "DLL", there is only this.
This i miss, but can u give me the link, please, i have look for a lot, but did not find in vaio update
here the link:
http://www.vaio-link.com/downloads/info/info.asp?l=it&url=Downloads/SO/A/VES/SOAVES-00824540-UN.exe&...
Please, help me and confirm.
thank a lot
Hi osservatorio,
I am a little confused here as the links that you post result in a download for the Italian language (of which I am not familiar). But in essence there is only one download that you require.
Download the Preinstalled Utilities for Windows XP from Vaio-Link (this is model specific). This file contains all of the pre-installed utilities for your model.
Extract the file using either Winzip or Winrar and you will then see Installer folders numbered 1 to 14 plus a couple of other utilities.
Install the following in this order:
1 Sony Utilities (Utils installer 1)
2 Sony Shared Library (Utils installer 2)
3 Vaio Event Service (Utils installer 5)
If this is still not clear then please do post back for further assistance.
Dear Rich912!
I am not the original poster, but I had the same problem and it worked well for me. Even the S1 and S2 which were not working do work now.
Thanks a lot for your help!
Markus
Thanks for the feedback Markus
I’m pleased that it worked for you; let’s hope that osservatorio has also had the same result:smileyconfused:
I seem to have a similar problem.... is it really necessary to rebot.
I have a sony vaio vgn fs
Hi trishw78 and welcome to the forum.
