I have a VAIO FE28H, i would like to know if it is a problem to replace the 4200 Tf/mn disk by a 7200 Tr/mn disk.
Regards
Should be no problem, as long as they're the same size and use the same system (SATA / IDE)
Kee-Lo means the same physical size so it will fit in your Vaio.
100mm X 70mm X 9.5mm
Not the storage capacity !!!
I think you have 160GB SATA 2.5 Inch supplied with your FE28H.
I don't think you can get bigger than 160GB 5400 RPM but you can get 7200 RPM SATA drives.
You will have to Google - I can't find one bigger than 100GB - SEE THIS ONE
