Can anyone advie me?I have just don a System Recovery which has left me with a few problems.
I get a pop up after signing a box "Club Vaio" with a one line message "can only sign if I am a Vaio member" there is no other facility but to close the box I seem to remember a fix was available, will this help? Carl
Hi Carl,
Sony have released a My Club VAIO patch that should resolve this problem, see here
if the patch does not stop the problem then see the solutions below.
You should be able to stop My Club Vaio.exe from starting if you go to start > All Programs > Accessories > System Tools > Task Scheduler..
In task scheduler you should have three windows, Overview of Task Scheduler, then below this Task Status and finally at the bottom Active tasks..
In task scheduler go to the bottom section of the centre column (called active tasks)
Double click LaunchMCV and in the new window select delete...
Many thanks again for your Thalamus much appreciated. Carl
You're welcome Carl..
