Hi, I have adjusted the Power Settings so that (at least I think) the system does not switch off screen or disk when plugged into the mains. I need this so I can e.g. set a virus scan to run late at night. Every morning I find the machine is "dormant" - disk is powered down and there are error messages about network being unavailable, virus scanner not having run etc. If I hit any key it all srpings to lfe but it's not what I wanted. Any ideas? Thanks.
Sorry if this has been asked before but without a search facility it's a bit hard to do a search 😞
I'm not sure what's in the a series power settings so I may be a little off, but it could be that you have only set the laptop to stay on if you are on battery? or just on ac? try setting everything to never turn off (that's system hibernation, monitor and hard disks) and see if it still does it. Also check your laptop isn't going into hibernation, there should be setting to simply turn that on or off. By the way if you are only running a virus scan you can allow the screen to go off, it doesn't stop the computer working. You just can't see anything.
Might seem obvious but what settings do you have on your screensaver?
Make sure you setup the power settings in powerpannel too.
Thanks for all your replies. It seems that disabling Hibernate did the trick. I had already played with the Sony-specific power settings but it was obviously Hibernate. I came to it this morning and the scan had run.
Cool
Good group effort too :smileygrin:
*nods head*
