Hi all
I hope someone can help. I've got a VGN-C1Z that to date I have been very satisfied with.
However, I am now experiencing problem when I plug to AC cable into the laptop. If I am running on battery and then insert the AC adaptor, the screen goes black and nothing will bring the laptop "back to life". The only solution to the problem is to remove and replace the battery and restart the system.
Has anyone got any suggestions as to what to the problem may be and what I could do about it?
Thanks
Matt
bump!
Sorry Matt - it sounds like a one off fault.
I suggest you contact Vaio-Link Support as it sounds like a repair will be needed.
