I switched on my AR61M today and it didnt pick up any wireless networks and then I noticed the WLAN light was not showing on the front of the laptop so I flicked the switch on only to find it was already switched on but the light was not on.
When I try to connect it thinks that the wireless tab is switch off but it isnt. Ive tried rebooting but still no luck.
HELP
I switched the laptop on today and found the WLAN switch was off, I must have done it accidently whilst picking it up and now it doent work again
I might have to make that call then.
I was online right now using my USB network adapter and got a bit bored so I started flicking the switch and after 15 secs the WLAN light came on so its definetly a fault then
i had the same problem also on my AR-21S, the wireless was working 10 minutes and then it went off. I noticed that after several restarts than the wireless turns off in Power Saving mode (although i check the options for Not power saving the wireless) and also in Vista Basic theme i got the same problem. So i tried the Vista Aero theme with the power options On High Performance and it works just fine. It may sound weird but with those options it works perfectly
