BOOT EXTERNAL in BIOS ? SO THAT IT IS WORTH?
profile.country.es_ES.title
pariope41
Bezoeker
Good night gentlemen. Pardon to be Spanish and that you understands to me bad but has goes my doubt. Option BOOT External of the BIOS, that utility has this option? greetings
4 ANTWOORDEN 4
Blencogo
Hi
You can only boot from an external USB floppy disc drive (1.44MB MF-2HD).
You cannot boot from any other USB connected device such as a hard drive or a CD/DVD drive or from any memory card.
:wink:
pariope41
Bezoeker
Have you proved(tried) it? Since it(he,she) might start(extract) from a hard disk for usb? I was thinking that if one could... Since it has to be this key usb? Regards.
Blencogo
No it will not work from a hard drive or a DVD/CD drive connected by USB.
The boot takes place in DOS and the USB ports are not supported except for the floppy.
No funcionará con ningún dispositivo conectado con los puertos del USB.
Solamente la 'floppy drive' 1.44MB trabajará.
Comenzar su DOS de las aplicaciones de la computadora y éste no apoya el USB.
:cry:
pariope41
Bezoeker
Thank you for the answer. Since tiny disappointment I am llebado, because he(she) was studying the possibility of doing it. For Fireware cannot one not either? Graces(thanks) and regards
