Hi I have just setup my new ar61m but it wont find any bluetooth devices. How do I get the bluetooth working on my old vaio the drivers were already installed here apparantly not.
also which version of vista ultimate should i buy 32 bit or 64 bit for this cpu t7500.
regards
Peter
Hi Peter,
according to the AR61M's specs your Vaio does not have bluetooth capabilities..
You can view the AR61M's specs by clicking on the following link: AR61M specifications
thx i assumed it would have, will have to use the bluetooth dongle that came with the keyboard and mouse.
on the question of vista ultimate which version should i buy 64 or 32?
Hi Peter
The choice would have to be yours..
Honestly I would stick with Vista Home Premium but if you need to upgrade to Vista Ultimate then I would opt for the 32bit version.
The reason being that the 64 bit drivers released by Sony have only undergone limited testing and are being released as is. You can see the list of 64 Bit drivers by using the following link: Vista 64-bit drivers
