Hi.I'm new user and owner of VGN-FZ21M.My problems is i dont received the free movie of spiderman 3.Can anyone tell me where to contact?.Thanks
I´ve received mine today...
Almost 2 months of wait...
Did you find that your disc worked ok?
Or did you need to update drivers?
I have updated drivers but it still does not want to play.
I thought I had to dleted the application and re-install it as the update driver too did not work.
Now I've deleted the application and am lost I dont know where to get the application back from?
Pls can anyone help?
Hi Mitch,
Win DVD is unfortunately one of the few pre-installed applications that can only be reinstalled by doing a recovery via the Vaio recovery utility..
Make sure you back-up important data before you run the recovery utility.
If someone can traduce this from the spanish, I've a solution. Sorry for my english, it's poor!!
Me descargue el "WinDVD 8 Platinum", y le puse un serial que medejo un amigo.Los parches que ofrece SONY, son para la versión "WinDVD BD 8" asi que haciendo un downgrade bastante grande, me rebajo mi propio "WinDVD 8 Platinum" y le dejo en "WinDVD BD 8", que tiene lo justo para leer DVDs y Blu-Ray, pero es especifico para VAIO y es de la que te dan soporte. ¿Como lo hago? otro amigo mio tiene un FZ11Z, con el "WinDVD BD 8", asi que me copio en un pen-drive todo lo que hay en la carpeta C:\archivos de programa\InterVideo\DVDBD8 del VAIO de mi amigo y a continuación lo pego en la carpeta C:\archivos de programa\Intervideo\DVD8 de mi ordenador, lo que copiado en el pen-drive y le doy a que sustituya todo lo que tenga el mismo nombre.
Y ya tenemos el ¡¡¡¡WINDVD BD 8!!!!
