Bonjour,
J aimerai savoir si le Vaio VGN-FE31H supporte de la memoire PC2-5300? en effet d origine se sont des 4300 mais je veux pas grille mon portable, alors si quelqu un a deja installe ca qu il me le dise si possible merci.
Hi, i would like to know if the Vaio VGN-FE31H accepte PC2-5300 memory ? thanks for your answer.
Arnaud ROQUE
Hello mate. Yes that s fine. it is type of memory that FE31H would accept. on the other hand, i would like to ask you very important question. I have also FE31H and i m having big problems with it. I had to replace the first one that i bought due to battery problem. What happens is that the laptop does not show 100% when i charge it. It shows only 90% instead. And give 10 min. it would go down to 75%. So i would like to ask you that if you ever experienced anything like this with your FE31H? oh by the way it s quiet recent but my one also started to make funny noise that such as you would see in old laptops. it s not loud but its like you constantly scratching something. do you also have this mate? Thank you very much indeed.....
Sorry but i haven't problem with my vaio and no problem with my battery. Perhaps you must contact technic support about Sony.
thank you for your answer about memory kit
Arnaud ROQUE
Oui mais ils marchent pas a 5300, ils marchent a 4300.
