Solved! Go to Solution.
Hi P
This has happened to our Sony TV a few times recently. No matter what I tried via the various TV menu options would not cure. So I just powered off/on the BT hub, even though the hub was working at the time for my laptop.
All the best.
Dodger
Thanks - this worked.
I'd be interested to know why this problem occurred and if there's anything i could do to avoid it happening again.
So restarting the modem fixed the issue? . I would have never guessed that restarting will fix it.
