I want to connect my laptop to my KDL40EX724 via direct Wi-Fi but my laptop is asking for the pin code. Does anyone know what this is? Thanks...
It's used if your network router is configured to use WPS (Wi-fi Protected Setup). WPS lets you use a push button or PIN instead of entering a network name (SSID) and wireless security details by hand. The PIN is either on a product label or perhaps on a utility screen for your router. The PIN is entered for either the router or for the wireless device that wants to join the network.
Check out the flow chart here: http://pdf.crse.com/manuals/iManuals/eng/EX72x_wifi/ft_wfintegrated.html for details on the various setup types for your TV.
When the TV displays "Please connect..." select Options / Manual / Other - the WPA key (PIN code) is then displayed
