I have had my tv wall mounted and I know want to use the stand but I cannot get it to fit the stand has under neath the following number 3-284-869 L/ML/M
the bracket on stand has M WRITTEN ON IT but does not line up with the holes in the tv ? Any help please thank you
Hi @Boiardi
Would you please let us know the full model number of your TV (it will start with KD).
KDL-46W4500
Hi @Boiardi
As far as I can see the stand you are trying to use is for a 32 inch TV which could explain why the holes don’t line up. One work-a-round may be to try a universal tabletop TV stand using the same holes as your wall mount.
