Just purchase my new Sony kdl-40ex723. I have attached a USB memory stick 16Gbytes to trial HDD recording. I can read the media I have already on the memory stick, but I cannot record.
Whilst watching freeview HD BBC1 I try pressing the record button, and get the following message
"Recording can't start as no registered HDD is connected. Please connect USB HDD to enable recording"
The memory stick is formatted in FAT32, but I cannot see any way of getting it to record or register the HDD
Any help welcome
Solved! Go to Solution.
have you to register your hdd or memory stick in the system settings -> recording setup -> hdd registration
but i dont think you can register hdd's smaler than 32GB. But try it
anyway you cant record anything before you register your device and be aware that anything stored on the device prior to registration will be deleted from the device whan you register it.. good luck
Now You can record progam and content just from DVB-T. After update in cople weeks You will be able to rec from dvb-c and dvb-s.
Regards
Damac
I am glad to announce firmware we are waiting for
Regards
Damac
