Wondering if there is a list of supported devices for my TV ( KDL60W605B)? It works fine with my Google Nexus 7... but not with my MS Surface 3: The surface finds the TV, the TV announces it is setting up the new device... but then reports failure, every time. Pretty annoying, one of the reasons I chose this TV was for its published Miracast support - which is a standard that should ensure it works with ALL certified devices!
Hi
To see which products are Miracast certified, see:
http://www.wi-fi.org/discover-wi-fi/wi-fi-certified-miracast
Doing a search for Surface 3, brings up 3 models, all miracast certified - source.
Considering that your nexus works, means the tv does work, so it appears that theres a problem with the MS surface that you would need to look at or seek further advice from MS.
Cheers
It doesn't work with any other Windows device I have either...
