Hi, I have a Sony Bravia LCD KDL-32D3000. The TV has just started with the vertical lines which indicate to me from research that it is a bad T-CON board. However, the last few nights I have been able to get the tele working and the vertical lines to disappear by leaving the tele or plugging different things in such as an xbox. would this say that the T-CON board is faulty or is it the cables going into it are loose? Thanks.
Hi JSummers00, hopefully another community member can shine a light on this for you. In the meantime you could also contact the technical support team for advice via this contact form.
