KDL-46EX503 incorrect colours when connected to Laptop
SOLVED
profile.country.en_IE.title
harropda
When I connect my Lenovo T410 Windows Xp to the Bravia KDL-46EX503 the colours are wrong.  Greens display as red, blues as purples etc......
Have reset the TV Picture settings to no effect.  Have been searching for a driver or colour profile for the TV to be used on the laptop, but no joy.
This TV is only used for PC connections.  Any ideas?
1 ACCEPTED SOLUTION
Accepted Solutions
Watashiwateshdes
Contributor
I have experienced incorrect colours, usually a green colour cast when my VGA cable was damaged. If this has already been swapped, a few more things for you to try
- Try a different resolution
- Try a different refresh rate
- If possible try a different TV or laptop
The other things that could be wrong would either be the VGA port on the laptop or TV, even just a wiggle on each connection might give you a slight change.
1 REPLY 1
Watashiwateshdes
Contributor
