KDL-40EX723 ethernet speed
SOLVED
edtheduk
Hello,
I searched the spec, no info.
I just wondered what the connection speed is? I have the wired connection and assumed this would be the fastest. I don't think think it operates at gigabit but I could be wrong. I have a gigabit switch and hoped that the TV could support these speeds too.
Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Sony recommend a high speed internet connection, 2.5Mbps Bandwidth and 10Mbps for HD content, and if using a wireless connection (not in your case) a 802.11n wireless router.
3 REPLIES 3
Bravia55HX
copicke45
It's a 100Mbps Ethernet Interface. The TV doesn't require any more than that - HD video only requires 10Mbps and unlike a PC there is no multi-tasking!
KDL-CX520
Just FYI
http://en.wikipedia.org/wiki/Bit_rate
Video
  • 16 kbit/s – videophone quality (minimum necessary for a consumer-acceptable "talking head" picture using various video compression schemes)
  • 128 – 384 kbit/s – business-oriented videoconferencing quality using video compression
  • 1.15 Mbit/s max – VCD quality (using MPEG1 compression)[15]
  • 3.5 Mbit/s typ - Standard-definition television quality (with bit-rate reduction from MPEG-2 compression)
  • 9.8 Mbit/s max – DVD (using MPEG2 compression)[16]
  • 8 to 15 Mbit/s typ – HDTV quality (with bit-rate reduction from MPEG-4 AVC compression)
  • 19 Mbit/s approximate - HDV 720p (using MPEG2 compression)[17]
  • 24 Mbit/s max - AVCHD (using MPEG4 AVC compression)[18]
  • 25 Mbit/s approximate - HDV 1080i (using MPEG2 compression)[17]
  • 29.4 Mbit/s max – HD DVD
  • 40 Mbit/s max – Blu-ray Disc (using MPEG2, AVC or VC-1 compression)
