I have a PS3, HTIS-100 AV amp and a Samsung 3D tv. I f I connect the PS3 directly to the TV the PS3 recognises the 3D TV and will play 3D fine. If I then connect the PS3 to the amp and run the PS3 video set up it does not find the 3D tv. Is their a way to play 3D through the AMP or am I going to have to connect the PS3 to the TV and then using optical connect the TV or PS3 to the amp for the sound?
since its only audio your concerned with an optical out to your Amp is fine.
I also have the same setup I've paid a lot of money for the system including over £300 just for the best i can afford cables (monster) and i would like to watch 3d on my TV through a single cable through my HT-IS 100 as i have cable in the wall (no room for more cable) and not use a optical cable for sound as this defeats the objective of having a home theatre system with switchable hdmi the system switches TV to 3D on but no picture but that could be anynet+ doing the switching not the HT-IS 100
