I had a decoder connected to my KDL-32cx520 via SCART cable. I removed it as now I'm using a HD decoder. When I go selecting the inputs onscreen I still see the AV SCART input highlighted, although there is no such thing connected to my TV, beside HDMI connections. How can I make it not to be highlighted any more? I'd really appreciate your help! Thank you!
Solved! Go to Solution.
http://pdf.crse.com/manuals/iManuals/eng/CX52x_o32/st_avpreset_europe.html
"... Settings/Home Menu > External Inputs > AV Preset
Assigns an icon or name to external equipment.
Select [Auto] to display icons or names only when the equipment is connected, or [Always] to display regardless of connection status.
