Connecting a KDL-46EX524 to a DAV-DV280
SOLVED
mark-Benji
i have just recieved a KDL-46EX524 as a replacement for a faulty TV. In place already i have a home cinema Sony system - DAV-DV280. Connections seem straight forward. So TV HDMI 1 into the HDMI out in the home cinema System (the only HDMI port so can't go wrong there!). Also i have connected the scart form the TV to the DAV.
However all i get from the home cinema system is 'white' noise. The Bravia synch works fine, the TV recognises the cinema system so all seems fine apart from the most important part - being watching Sky on the TV with the sound comming out of the cinema system. Any advice much appriciated!
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
the DAV is limited in its capability as a home cinema system as theres no audio inputs, the most you can expect is dolby digital from dvd,s, only video regular or upscaled is possible to your tv via HDMI out, the scart connection is not needed so take it off, and since you have no audio inputs you cannot connect the sky box to it for sound
2 REPLIES 2
Bravia55HX
mark-Benji
Thanks - i suspected as much. i guess i had better chose a new system.
