I am not sure how to explaing this
When we go into settings for xperia neo/arc (did not check in any other models) there is a white patch that is coming once we reach the top/bottom end of the menu i.e when you scroll down and keep holding till the top or bottom.. I was a bit releived when i identified that this was also seen on the arc.. so my question is :
Is it as per design? If so y ?
It seems like the screen is having some issue when that white patch is coming...
If you are not able to identify what i am saying i hope i can upload a pic..
Any suggestion is highly appreciated..
Regards,
Nidhin
Solved! Go to Solution.
also..when u exit from the menu and return to the main homescreen..
u'll see a marquee type of thing above the 4 default icons..
i mean there will be a white light goin from left to right..
sony sure has done everything even small things like this to enhance the styling
no its the design, no worries
it tells u that u cant scroll more up or down..
its normal
and yes i understood what u meant..
