can't use the phone funy message on screen "triangle with an exclamation mark inside and a mob phone in front" any one knows what to do? pls pls
SOLVED
Not applicable
who know how to doit?
12 REPLIES 12
Not applicable
have you installed any kind of task killer recently? very strange issue, I strongly recommend to repair/reinstall your software... then would check for reception and normal use before update or backup anything else...
Not applicable
do you know how to reinstall the soft for the phone and how can you flush it ?it started to work again after i've done an update but now i've lost the reception. can anything be done about it???
Not applicable
just follow my previous suggestions once again to see if it will work and fix the issue.
