I left my phone to sleep. i remember it was 49%. when i woke up, i checked the battery. It had depleted to about 41% ! I only left it sleep for about 7hours and it depleted about 7%. is it normal ?
i already turn off all the things like WiFi, Bluetooth, Internet, and force stop the needless application running,
when i checked the what has consumed the battery it says :
Display 60% for 2h 46m 53s
Cell Standby 17% for 1day 1h 18m 47s
Phone Idle 15% for 22h 32m 0s
Android System 2%
com.sonyericsson.home 3%
there !
thanks for your opinion
Solved! Go to Solution.
as uliwooly said..it is normal..even my arc 's battery's the same..
i know its odd but we cant do anything.
this is your first smartphone isn't?
yes it is normal, in fact only 7% is really good, battery on a smartphone last between 8-12hrs a day
you can improve battery life by
turn off wifi, bluetooth, gps and lower brightness
if you don't use 3G/Internet you can turn off your data
all that will improve your battery life
you can use Quick Settings app
https://market.android.com/details?id=com.bwx.bequick&feature=search_result
or
this great widget
Power Control
https://market.android.com/details?id=at.abraxas.powerwidget.free&feature=search_result
uhm yes , this is my very first smartphone, and I amazed of how the battery works!
what do you mean by 7 % ?
what i want to ask is : is it normal for the phone idle? it consumes about 1% for about 1hour idle.
is it okay for me to left my phone charged while i was sleeping?
thanks b4
you lost 7% charge over night, so that's not bad. that's what I meant
you can leave your phone charging overnight, once your phone reaches 100% it will stop charging your phone, once it reach 95% or so it will recharge your phone
so that is what u meant. 7% for standby of 7hours even WITHOUT TURNING THE BLUETOOTH/WIFI/MOBILE DATA ON ? just want to be sure that 1 idle hours without doing anything needs 1% of battery
well yes...
u can install this..
https://market.android.com/details?id=com.latedroid.juiceplotter&feature=search_result
and it'll give better view on ur battery;s performance..
just check it out..
if i find any thing abnormal i refer to this app and it tells at what time the battery depleted the most
you can also check this video (it's for the X10 but the same is true to most if not all smartphones android/ios)
