- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I just got a 16 GB microSDHC class 10 card. But before I mount the new card onto my phone, I want to have all the data of previous card on the new card. How can I do that?
I have apps, music and image files etc. on my old card. I didn't find any such option of backing up my memory card. Please help me transferring my data from old card to new card. (Apart from manually copying to my computer's HDD and pasting to my new card, since I won't be able to have my apps then)
So in a nutshell, I want to backup my old memory card and restore it back to my new card.
Please help.
Thanks in advance,
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ok on your PC
1) open any folder -> click on tools -> properties -> view -> show hidden files
2) mount your phone with the NEW SD card and delete everything (save any file that you might want to keep)
3) swap SD cards, mount the old SD card, go to your SD card, press Ctrl + A then Ctrl C, on your desktop create a new folder, open it, then press CTRL + V
4) swap SD cards, mount the new SD card, open the folder you just created, press Ctrl + A then Ctrl C, open your SD card, Ctrl + V
see if that solve the problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ok on your PC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
other methods to backup your phone
Backup & Restore app
if you need the app you can use this link instead to download the apk
http://www.megaupload.com/?d=I5CJUPJV
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks uli... i went for the first option...the good old copy paste...it worked just fine
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
anytime
