Xperia M showing 800Mb of RAM instead of 1GB
SOLVED
pattanur
My Xperia M is showing RAM as 800 MB, but in all the specifications it's mentioned as 1 GB.
Is sony giving false information to the customers.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
3 REPLIES 3
Uliwooly
part of RAM its not user accessible, that's why you only see 800MB
Don't forget to give Kudos
Uliwooly
This thread should answer some of your questions
http://talk.sonymobile.com/t5/Xperia-arc-Xperia-arc-S/Actual-RAM/m-p/89814/highlight/true#M7902
Basant
Please do look at all other makes also before you doubt Sony.  Which other brand gives you the complete ram mate??? Industry standard is to reveal the total RAM capacity and not the user available RAM. Same with internal memory.
However, if you keep your phone switched off i guess you will have the full 1 gb ram available. How you access it is your lookout tho Slightly_smiling_Face
