Phone Stuck On Boot Screen Loop - HELP!
SOLVED
TheOnlyPrincess
Hello!
My phone, Xperia M is stuck on the Xperia Boot Screen (with the colourful waves).
This happened today after I downloaded and installed Xperia Foggy Theme from Google Play Store. I selected the theme and it successfully changed to Foggy but as I went to unlock the screen, to go back into the phone to check my notifications, the screen would not come on. I pressed the power/lock key many times and the screen would not come on.
I pressed and held the power button until the phone showed some sign of life and this is when the Xperia Waves appeared. I took the battery out and replaced it to force shut down the phone but the phone wont boot further than the Wave screen.
I have removed the sim card and memory card from the phone and plugged the charger in hoping this would help but nothing.
I have also tried to connect the phone to the PC Companion but my PC will not detect the phone as the phone wont switch on. So i cannot try the repair option on PC Companion.
I have also tried pressing the Power Button and Volume Up Key until the phone vibrates but it does not do anything.
Is there anything else I can try to fix my phone? And will it be costly to get it repaired by Sony?
Please help! Thank you! Slightly_smiling_Face
30 REPLIES 30
Zooru
Following instructions on xperia softwear repair, but it wants me to unlock my phone, which obviously i cannot do as it will not load past the boot screen...how do I get around this???
Help!
Many thanks in advance
