Is it safe to use a flip cover which contain magnets ?
SOLVED
Swagata
Hi All,
I am using a flip cover (N-case ) which is contain 2 magnets. I just want to know will it effect my phone negatively ?
Please suggest
1 ACCEPTED SOLUTION
Accepted Solutions
Hampus
Champion
A very strong magnet can harm your device and in some cases cause a bad reception for example. But if they are weaker, the phone should not take any damage/or affect your performance.
If you begin to experience trouble while using this flip case I would recommend you to remove the magnetic (if it's possible) otherwise you should remove this case.
2 REPLIES 2
Hampus
Champion
Swagata
Thanks for the quick response.....:smileyhappy:
