xperia L wify connect issues
SOLVED
kohir2
When ever I try to connect to the wify in my office the wify does not connect at all.
tried restarting the device, tired in safe mode and nothing works.
when I do not connect to the wify provided by my office the signal streangth shows as excellent and the moment  I connect the signal streangth goes to poor.
 Please help me on this
Thanks,
Praveen
1 ACCEPTED SOLUTION
Accepted Solutions
manjuboyz
Contributor
Hi kohir2
>try removing all wifi networks on the phone using forget network, later restart the phone
>try adding your office network as first, try to connect now
Let us know
Manjuboyz Slightly_smiling_Face
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks Slightly_smiling_Face
4 REPLIES 4
manjuboyz
Contributor
Hi kohir2
Let us know
NOTE:
Alexander1
Champion
You can also take a look at the follow topic:
http://talk.sonymobile.com/t5/FAQ/Wi-Fi-problems/m-p/348104#U348104
kohir2
Thanks a lot Buddy.
it did work now.
my only concern if this is a one time issue or I will face this again Slightly_frowning_Face
Thanks,
Praveen
manjuboyz
Contributor
Hi kohir2
    nice to hear, that it is working, try hard reset once , i guess that may fix any issues
take care:)
NOTE:
