Wrong battery capacity detection during charging?
SOLVED
gigavolt
Hello.
When I am charging my Xperia L, battery capacity jumps from 82% directly to 100%. When I disconnect the charger, it jumps back to 82%.
After switch off/on the phone it is OK, it is normally charged to 100%. BUT ONLY ONCE. Next time problem repeats.
Please, is there somebody who know the solution?
Is it battery problem or phone or software?
It is from the beginning, phone works on Android 4.1.2.
Thanks for help.
1 ACCEPTED SOLUTION
Accepted Solutions
gigavolt
Thanks for link.
I have found the solution:
1. Switch off and on the phone.
2. Charge to 100%.
3. Leave phone connected to a charger for a long time, in my case for about 14 hours.
After these steps discharging seems to be slower and new charging went correctly.
13 REPLIES 13
profile.country.RO.title
_alexdon_
This should not be battery problem,it is software all the way.How long have you been having the phone?
alexdon
gigavolt
1 week only.
What would you recommend to me?
Have you ever heard about this?
Thanks.
_alexdon_
Yes,it will take some time until the phone will be used to the operating system.Do you restart the phone regularly?Every 2,max 3 days?
alexdon
gigavolt
Yes, but it helped only once. Next charging is usually next day or after 2 days and problem is still here.
_alexdon_
Try to never let the phone discharge until it turns off(between 1-10% always connect to charger).Restart it regularly.Sometimes you can even force restart(power button+vol up until the phone vibrates).Do not use battery savers,task killers.You have stamina mode and low battery mode.
alexdon
gigavolt
I have allready heard that is good to make 10-15 battery cycles, after it the battery is able to use full capacity.
But in this case once it is good and once not.
gigavolt
Thanks. We will see. I will try it.
_alexdon_
If you fully discharge it many times,you may end up with it never fully charging.But it is your choice,I only suggest things.
http://www.wikihow.com/Make-Your-Cell-Phone-Battery-Last-Longer
Here you see how to preserve battery,but I wanted you to see about the full discharge.
alexdon
gigavolt
Thanks for link.
2. Charge to 100%.
