- Als nieuw markeren
- Bladwijzer
- Abonneren
- Dempen
- Abonneren op RSS-feed
- Markeren
- Afdrukken
- Ongepaste inhoud melden
video keeps pausing
For a few weeks now I have had this problem: video and sound (in particular Youtube vid and BBC sounds) keep pausing, resume when the arrow head is pressed, but then stop again moments later.
First I tried restarting the phone. Then I tried emptying cache. Finally I tried installing a trusted cleaner, but it didn't work on my phone so I uninstalled. I also checked for apparent rogue apps. Then I switched my consuming to another device and hoped an update would solve it. Eventually I factory reset my phone - and still it happens.
Today I went through the apps again, and uninstalled a few I didn't need, and a few I can replace. Still it happens.
I read everywhere that it must be an app, which is my suspicion, but how, without uninstalling the lot, can I tell which is the rogue - or whether there might be another reason.
It looks as though I'm going to have to use my inferior device until upgrade time otherwise - which is about 18 months away!
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
Hi there, so the issue doesn't happen with all of the videos or media on your device?
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
I would say yes,it very likely does happen with all audio/video media: as I reported, I can't play BBC sounds or YouTube. Before I replied to you, I also tried Netflix and BBC iPlayer with the same results. I figure it might be an app, but I can't trace it - without starting all over again, I mean. Any suggestions?
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
You can try to troubleshoot these apps from the steps and this link and check if it will work or not: https://www.sony.co.uk/electronics/support/mobile-phones-tablets/articles/00235707
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
Thanks for the reply. I tried your solutions on the main two apps that are faulting: BBC sounds and YouTube (though there are others where video/audio refuses to play - ie starts and then stops very quickly. No change.
Please note: I have 114 apps on my phone. I can't identify one I have uploaded recently, so I suspect that if it is an app at fault, it must be an update. Might you be telling me that the only way I can possibly identify this problem - video stopping (not pausing, actually stopping) with the above two apps and others with video - would be to go through all the steps with each app, then test out the video/sound apps again? I do wish there were some other way. I miss being able to click on a youtube vid or switch my radio to my phone - even though the sound on this phone is not good.
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
You can try to enable safe mode on your device , that will disable all the third party apps, but you'll still be able to test YouTube as it is a preinstalled app, and check if the same thing will happen or not ?
Also what is the model of your device ?
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
problem.
My phone is an Xperia L4.
Sylvia
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
Are you wearing earphones when this occurs by any chance?
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
doesn't happen in safe mode, I'm assuming it's an app. Any easy way of
telling?
Sylvia
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
No real way to tell aside from removing 3rd party apps, in order from the apps installed most recently to when you noticed the behaviour.
- « Vorige
- 1
- 2
- Volgende »
