UDP-x700 wont play MkV Atmos
mow955
The vast majority of lossless Atmos demos from https://thedigitaltheater.com/dolby-trailers/ are in the mkv format.
I have no luck in getting my UBP-x700 player to play these from my hdd. I can play mkv separately , I can play Atmos separately, but not combined from a single mkv file.
It’s been over a year since a firmware update was released, so I guess we won’t be getting any more.
Has anyone got any help on this subject
4 REPLIES 4
Marino.Manolo
If you want to try...
The HD Audio (Dolby Digital Plus, Dolby TrueHD, DTS-HD High Resolution Audio, DTS-HD Master Audio, Dolby Atmos and DTS:X) is not output by bitstream. • Set [BD Secondary Audio] in [Audio Settings] to [Off] (page 21).
https://www.sony.com/electronics/support/res/manuals/4698/6014f2c77e20f44605ea8821bf88a55b/46984071M...
mow955
Have you managed to play stated files over usb? Or is it just a suggestion, rather than an answer?
I have set  up my system as stated in the manual, and every other conceivable variation.
This still gives me an unsupported audio format.
Marino.Manolo
Only a suggestion...
mow955
Thanks.
It’s unfortunate that there doesn’t seem to be any information on this.
Would anyone have any knowledge of converting mkv to m2ts?
The x700 can play m2ts files with Atmos, but I cannot find a way to extract the audio from the mkv file, and then remux it back into a m2ts file.
I’m starting to wish I hadn’t bought this box
