STR-DH810 display failing.
rgale47
I have an STR-DH810 home cinema amp on which the front LCD display keeps going blank - almost as though the display is 'switching off'.
Whever this happens, a gentle tap anywhere on the unit brings it back up again - sometimes it stays on for a few minutes, & sometimes for a few hours, but it always goes blank again eventually.
I've just been putting up with it as the issue doesn't affect the operation of the unit at all which contines to work perfectly normally.
Has anyone else experienced a similar problem.? I was wondering if anyone could shed some light on what might be causing the issue & whether or not it's fixable.?
Many thanks in anticipation.
12 REPLIES 12
Mooly01
Contributor
There was a similar thread here:
https://community.sony.co.uk/t5/home-cinema-projectors-players/display-not-working-str-dh820/td-p/24...
Have a look at the posts and picture. This kind of issue is fairly common.
rgale47
Yes, it was a couple of dry joints. I’m not sure where or which ones, I got
it professionally repaired in the end.
Mooly01
Contributor
Thanks for the update. Pleased to hear you got it sorted.
