Hi all,
I recently bought SMP-N200 media streaming player and currently in the process of setting the thing up.
I have an issue with configuring the proxy server. The proxy server I need to connect to requires user/password authentication.
- First, I tried just with the IP address and port, assuming it will ask me for a user and password afterwards which it did not.
- Second, I tried to use the following syntax:
-- Proxy Server: user:password@IP
-- Proxy number: port
Which didn't work either.
Has anybody figured out how to use a authentication-required proxy server?
Thanks,
Tom
Hi Tom,
I have exactly the same problem as you. Hopefully someone - maybe from Sony
- will reply.
I am very frustrated by the limitations with the media player - I hope this is not going to be another one!
- Ian
