No Internet via Homeplug
FarmerHowie
Ive got the BDP S370 connected to my router by Devolo Homeplug.  Initially accessed internet beautifully... now just gets message cant access internet.  Tested the Homeplug units, they are fine.  Help!!!!
5 REPLIES 5
flintst0ne
New
Try rebooting your Internet router first and if still no joy then reboot your BDP S370?
CheerZ and goodluck
Catmambo
Contributor
Make sure your homeplugs aren't in an extension block as this affect them also.
thanks
FarmerHowie
Thanks for the suggestions.... tried them all... reset router, reset DVD player, even reset and reprogrammed homeplug system... even swapped around homeplug units...avoided extention cord use... still not working.. still get internet connection failed message.  The frustrating thing is that the system worked just fine when I first configured it a week ago.  When I went to use it again...no joy.  Any more ideas please????
Catmambo
Contributor
Does it work if you connect directly via Ethernet. Really need to try and pinpoint where the fault might be.
Thanks
wolverine090175
Hi there. We're having the same issue with BDP-S185 and powerline adaptors. Did you manage to resolve the issue FamerHowie?
