sky+ HD box connected to NSZ-GS7 cannot use epg for sky keeps skipping two genre or two programmes same issue using front of controller or arrow keys on keyboard sky box model is amstrad DRX 890 tried different hdmi leads v1.3 & v1.4 contacted sony they believe box to be faulty ? this model does'nt show on database only when you input manually
Solved! Go to Solution.
Apparently the update is staggered over a few days so hopefully you should be able to update before the end of the weekend. Sorry I can't be more precise.
thanks
Ah right ok thanks - no problem. I will report back with findings once updated.
thanks once again
this lastest update solves this problem
Likewise! Update came through this morning and can also confirm that it resolves the Sky+hd Programme Guide skipping.
I can now store that Sky remote control away in the cupboard!
Thanks Sony
