I forgot to say, I bought an optical cable, but not sure whether to plug it into the DAV-SC8 and PS3 or the TV (tried both) and not sure which settings to change in TV and/or PS3!
Solved! Go to Solution.
Hi johnnymac62.
Does this help: -
You can download the full Manual from here: -
http://pdf.crse.com/manuals/4248417112.pdf
Hi johnnymac62.
Does this help: -
Many thanks thats great, I'll give it a go. Do you know which settings to change in TV and/or PS3? It asked me to select an output format for my old DAV-SC8, but I had no idea which to select (dolby 5.1???)
you should be able to set DTS to DTS and DD to DD, otherwise if you can select Auto then do that.
Many thanks, but I don't recall seeing DTS or DD in any of the settings on the PS3 or the Bravia TV, could you please tell me where I find them? Also, do I connect the optical cable betwwen my old DAV-SC8 and the PS3 or the Bravia TV?
use optical to the DAV,
and i hope this link below helps, i got shot of my PS3 within 10 mins of having it!.
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
You will need to go from the PS3 to the system (not the tv) and then select Digital Out (Optical) in the Audio Output Settings on the PS3.
Many thanks, I'll try that
Many thanks,
i did try connecting one end of the optical cable to my old home cinema DAV-SC8 and the other end to the PS3, rather than the TV, but that didn't work either - perhaps I messed up when asked to select an output format as I didn't know which of the several options to select! Should it be the dolby 5.1 option?
in your case, yes!
